[GRASS-user] Grass7 GUI does not start
Vaclav Petras
wenzeslaus at gmail.com
Sat Mar 26 14:08:13 PDT 2016
On Sat, Mar 26, 2016 at 4:16 PM, ddarlac <dimntar at rutgers.edu> wrote:
> yes I did - the result is nothing (no gui, similar to the other attempts)
You can try to run the Python code directly. Somewhere in your installation
should be "gui/wxpython/wxgui.py". From GRASS command line run something
like:
python /usr/lib/grass70/gui/wxpython/wxgui.py
or you can try just:
python $GISBASE/gui/wxpython/wxgui.py
which is basically what g.gui does in the background.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160326/60c88915/attachment.html>
