[GRASS-user] Grass7 GUI does not start
ddarlac
dimntar at rutgers.edu
Sat Mar 26 20:16:34 PDT 2016
thanks,
that helped a lot - wxgui is located in '/opt/grass/gui/wxpython'
running python wxgui.py is giving me
'segmentation fault'
running with sudo (although I have user ownership) I get the following:
Unable to import pyGRASS: grass_gis.7.0.3 not found.
Some functionality will be not accessible
NumPy not found.
This module requires the NumPy module, which could not be
imported. It probably is not installed (it's not part of the
standard Python distribution). See the Numeric Python site
(http://numpy.scipy.org) for information on downloading source or
binaries.
ERROR: MAPSET Rock - permission denied
File "wxgui.py", line 37, in <module>
from lmgr.frame import GMFrame
File "/opt/grass/gui/wxpython/lmgr/frame.py", line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/opt/grass/gui/wxpython/lmgr/layertree.py", line 37, in <module>
from mapdisp.frame import MapFrame
File "/opt/grass/gui/wxpython/mapdisp/frame.py", line 64, in <module>
class MapFrame(SingleMapFrame):
File "/opt/grass/gui/wxpython/mapdisp/frame.py", line 70, in MapFrame
page = None, Map = Map(), auimgr = None, name = 'MapWindow', **kwargs):
File "/opt/grass/gui/wxpython/core/render.py", line 414, in __init__
self.mapfile = grass.tempfile(create = False) + '.ppm'
File "/opt/grass/etc/python/grass/script/core.py", line 736, in tempfile
return read_command("g.tempfile", flags=flags, pid=os.getpid()).strip()
File "/opt/grass/etc/python/grass/script/core.py", line 445, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
File "/opt/grass/etc/python/grass/script/core.py", line 312, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.tempfile', '-d',
'pid=4416'] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
I have numpy installed, maybe it cannot find it; but in anyway I do not
think this is the main problem
any help?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Grass7-GUI-does-not-start-tp5257181p5258503.html
Sent from the Grass - Users mailing list archive at Nabble.com.
