[GRASS-user] r.to.vect.lines addon not working
Carlo Cormio carlo.cormio at gmail.com
Mon May 2 01:14:46 PDT 2016
Hi all,
I'm facing problems with r.to.vect.lines addon module on different
platforms (Fedora 23, Windows 10).
I compiled GRASS GIS 7 from svn source (updated right now to GRASS GIS
7.0.5svn R68347), see configuration at the end of the e-mail), then
installed the addon using g.extension. Installing works fine, but when I
run the command (either from GUI or command line) it provides me the
following error:
   File
"/usr/local/grass-7.0.4svn/gui/wxpython/gui_core/prompt.py",
line 263, in OnItemSelected
self.cmdDesc = gtask.parse_interface(cmd)
   File
"/usr/local/grass-7.0.4svn/etc/python/grass/script/task.py",
line 520, in parse_interface
"<{name}> module: {error}").format(name=name, error=error))
grass.exceptions
ScriptError
Cannot parse interface description of<r.to.vect.lines>
module: not well-formed (invalid token): line 17, column 19
The last two lines also appear in grass shell when I launch GRASS 7.
I have no ideas about the origin of such error, any idea?
Thank you,
Carlo
Informazioni di sistema
Versione di GRASS: 7.0.5svn
Revisione SVN GRASS: 68347
Build Date: 2016-05-02
Build Platform: x86_64-pc-linux-gnu
GDAL/OGR: 2.0.2
PROJ.4: 4.9.1
GEOS: 3.4.2
SQLite: 3.11.0
Python: 2.7.11
wxPython: 3.0.2.0
Piattaforma: Linux-4.4.8-300.fc23.x86_64-x86_64-with-fedora-23-Twenty_Three
