[GRASS-user] r.to.vect.lines addon not working
Markus Neteler neteler at osgeo.org
Mon May 2 13:09:52 PDT 2016
Hi Carlo,
I just tried on my F23 box, no issues there.
Idea:
On Mon, May 2, 2016 at 10:14 AM, Carlo Cormio <carlo.cormio at gmail.com> wrote:
> Hi all,
> I'm facing problems with r.to.vect.lines addon module on different platforms
> (Fedora 23, Windows 10).
> I compiled GRASS GIS 7 from svn source (updated right now to GRASS GIS
> 7.0.5svn R68347), see configuration at the end of the e-mail), then
> installed the addon using g.extension. Installing works fine, but when I run
> the command (either from GUI or command line) it provides me the following
> error:
> Traceback (most recent call last):
>   File
> "/usr/local/grass-7.0.4svn/gui/wxpython/gui_core/prompt.py",
                             ^^^^should be 7.0.5svn in your case
Be sure that you run "make distclean" , then compile.
best
Markus
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
