[GRASS-user] r.to.vect.lines addon not working
    CARLO CORMIO
    carlo.cormio at gmail.com
    Mon May  2 13:33:59 PDT 2016
Hi Markus,
Il 02/mag/2016 10:10 PM, "Markus Neteler" <neteler at osgeo.org> ha scritto:
> Hi Carlo,
> I just tried on my F23 box, no issues there.
> Idea:
> On Mon, May 2, 2016 at 10:14 AM, Carlo Cormio <carlo.cormio at gmail.com>
wrote:
> > "/usr/local/grass-7.0.4svn/gui/wxpython/gui_core/prompt.py",
>                              ^^^^should be 7.0.5svn in your case
> Be sure that you run "make distclean" , then compile.
> best
> Markus
My fault in copy-paste action. I didn't "make distclean" at first version
update, and then copied the error message from grass his output. I saw from
system setting there was something wrong (grass gis 7.0.4). Then I compiled
everything in the right way (make distclean, svn up, compile blablabla,
make, make install) and checked add-on (working or not) once again, but
didn't replaced the error message (that was the same as the posted one) in
mail text, sorry.
Anyway, I will make a double check tomorrow morning and will let you know
(hopefully good news). I will try uninstalling and reinstalling the add-on.
Thank you,
Carlo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160502/c9352667/attachment.html>
