[GRASS-user] r.to.vect.lines addon not working
Carlo Cormio carlo.cormio at gmail.com
Tue May 3 00:26:55 PDT 2016
Good morning everybody,
a few minutes ago I removed r.to.vect.lines (g.extension -f
extension=r.to.vect.lines operation=remove) and reinstalled it again,
but get the same error once again:
   File
"/usr/local/grass-7.0.5svn/gui/wxpython/gui_core/prompt.py",
line 263, in OnItemSelected
self.cmdDesc = gtask.parse_interface(cmd)
   File
"/usr/local/grass-7.0.5svn/etc/python/grass/script/task.py",
line 520, in parse_interface
"<{name}> module: {error}").format(name=name, error=error))
grass.exceptions
ScriptError
Cannot parse interface description of<r.to.vect.lines>
module: not well-formed (invalid token): line 17, column 19
Could it be related to ascii encoding or sth like this?
Thank you,
Carlo
Il 02/05/2016 22:33, CARLO CORMIO ha scritto:
> Hi Markus,
> Il 02/mag/2016 10:10 PM, "Markus Neteler" <neteler at osgeo.org
> <mailto:neteler at osgeo.org>> ha scritto:
> > Hi Carlo,
> > I just tried on my F23 box, no issues there.
> > Idea:
> > On Mon, May 2, 2016 at 10:14 AM, Carlo Cormio
> <carlo.cormio at gmail.com <mailto:carlo.cormio at gmail.com>> wrote:
> > > "/usr/local/grass-7.0.4svn/gui/wxpython/gui_core/prompt.py",
> >                              ^^^^should be 7.0.5svn in your case
> > Be sure that you run "make distclean" , then compile.
> > best
> > Markus
> My fault in copy-paste action. I didn't "make distclean" at first
> version update, and then copied the error message from grass his
> output. I saw from system setting there was something wrong (grass gis
> 7.0.4). Then I compiled everything in the right way (make distclean,
> svn up, compile blablabla, make, make install) and checked add-on
> (working or not) once again, but didn't replaced the error message
> (that was the same as the posted one) in mail text, sorry.
> Anyway, I will make a double check tomorrow morning and will let you
> know (hopefully good news). I will try uninstalling and reinstalling
> the add-on.
> Thank you,
> Carlo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160503/8ec5c56e/attachment-0001.html>
