[GRASS-user] r.to.vect.lines addon not working
Markus Neteler neteler at osgeo.org
Thu May 5 07:57:07 PDT 2016
On Tue, May 3, 2016 at 9:26 AM, Carlo Cormio <carlo.cormio at gmail.com> wrote:
> Good morning everybody,
> a few minutes ago I removed r.to.vect.lines (g.extension -f
> extension=r.to.vect.lines operation=remove) and reinstalled it again, but
> get the same error once again:
> Traceback (most recent call last):
>   File
> "/usr/local/grass-7.0.5svn/gui/wxpython/gui_core/prompt.py",
> line 263, in OnItemSelected
> self.cmdDesc = gtask.parse_interface(cmd)
>   File
> "/usr/local/grass-7.0.5svn/etc/python/grass/script/task.py",
> line 520, in parse_interface
> "<{name}> module: {error}").format(name=name, error=error))
> grass.exceptions
> ScriptError
> Cannot parse interface description of<r.to.vect.lines>
> module: not well-formed (invalid token): line 17, column 19
Mhh.. can you please try
r.to.vect.lines --interface-description
and check if it outputs XML?
Markus
