[GRASS-user] r.to.vect.lines addon not working
Carlo Cormio
carlo.cormio at gmail.com
Fri May 6 06:50:43 PDT 2016
HI Markus,
Il 05/05/2016 16:57, Markus Neteler ha scritto:
> Mhh.. can you please try
> r.to.vect.lines --interface-description
> and check if it outputs XML?
> Markus
this is the result (xml):
GRASS 7.0.5svn (MonteMarioZona1_3003):~ > r.to.vect.lines
<!DOCTYPE task SYSTEM "grass-interface.dtd">
<task name="r.to.vect.lines">
<description>
Convert raster rows to vector lines.
</description>
<keywords>
raster, conversion, wiggles
</keywords>
<parameter name="input" type="string" required="yes" multiple="no">
<description>
Nome della mappa raster di input
</description>
<keydesc>
<item order="1">name</item>
</keydesc>
<gisprompt age=""old" element="cell" prompt="raster";" />
</parameter>
<parameter name="output" type="string" required="yes" multiple="no">
<description>
Nome della mappa vettoriale di output
</description>
<keydesc>
</keydesc>
<gisprompt age=""new" element="vector" prompt="vector";" />
</parameter>
<parameter name="skip" type="integer" required="no" multiple="no">
<description>
Sample every Nth grid row
</description>
<default>
10
</default>
<values>
<value>
<name>1-100000</name>
</value>
</values>
</parameter>
<flag name="v">
<description>
Sample vertically (default is to sample horizontally)
</description>
</flag>
<flag name="help">
<description>
Print usage summary
</description>
</flag>
<flag name="verbose">
<description>
Output verboso del modulo
</description>
</flag>
<flag name="quiet">
<description>
Output quieto del modulo
</description>
</flag>
</task>
