[GRASS-user] r.to.vect.lines addon not working
Carlo Cormio
carlo.cormio at gmail.com
Fri May 6 06:59:44 PDT 2016
ALso XML Copy Editor analysis provides the same error message:
Error at line 17, column 26: not well-formed (invalid token)
It seems there's something wrong with gisprompt, but I'm unable to
understand and fix, sorry.
Thank you,
Carlo
Il 06/05/2016 15:50, Carlo Cormio ha scritto:
> HI Markus,
> Il 05/05/2016 16:57, Markus Neteler ha scritto:
>> Mhh.. can you please try
>> r.to.vect.lines --interface-description
>> and check if it outputs XML?
>> Markus
> this is the result (xml):
> GRASS 7.0.5svn (MonteMarioZona1_3003):~ > r.to.vect.lines
> <?xml version="1.0" encoding="UTF-8"?>
> <!DOCTYPE task SYSTEM "grass-interface.dtd">
> <task name="r.to.vect.lines">
> <description>
> Convert raster rows to vector lines.
> </description>
> <keywords>
> raster, conversion, wiggles
> </keywords>
> <parameter name="input" type="string" required="yes" multiple="no">
> <description>
> Nome della mappa raster di input
> </description>
> <keydesc>
> <item order="1">name</item>
> </keydesc>
> <gisprompt age=""old" element="cell" prompt="raster";" />
> </parameter>
> <parameter name="output" type="string" required="yes" multiple="no">
> <description>
> Nome della mappa vettoriale di output
> </description>
> <keydesc>
> </keydesc>
> <gisprompt age=""new" element="vector" prompt="vector";" />
> </parameter>
> <parameter name="skip" type="integer" required="no" multiple="no">
> <description>
> Sample every Nth grid row
> </description>
> <default>
> 10
> </default>
> <values>
> <value>
> <name>1-100000</name>
> </value>
> </values>
> </parameter>
> <flag name="v">
> <description>
> Sample vertically (default is to sample horizontally)
> </description>
> </flag>
> <flag name="help">
> <description>
> Print usage summary
> </description>
> </flag>
> <flag name="verbose">
> <description>
> Output verboso del modulo
> </description>
> </flag>
> <flag name="quiet">
> <description>
> Output quieto del modulo
> </description>
> </flag>
> </task>
