[GRASS-user] Advice on georectification procedure
Eric Patton
thepattonian at gmail.com
Fri May 13 06:42:23 PDT 2016
Hi list,
What is the best approach to take when georectifying a scanned, projected
map (but the projection is unknown)? Is it necessary to georectify the map
first into a lat-long location and *then* r.proj the map into a target
projection? This is the method I used, using 20 GCPs (reading lat-long
graticule intersections from the map) and a cubic rectification, but there
is still a lot of error (see attached; I overlaid the GSHHG coastline for
comparison).
I'm not sure if I am going about this the correct way.
Thanks for any thoughts,
Eric Patton <thepattonian at gmail.com>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160513/9caa84d2/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160513/9caa84d2/attachment-0001.jpg>
