[GRASS-user] Advice on georectification procedure
Anna Petrášová kratochanna at gmail.com
Fri May 13 06:48:54 PDT 2016
On Fri, May 13, 2016 at 9:42 AM, Eric Patton <thepattonian at gmail.com> wrote:
> Hi list,
> What is the best approach to take when georectifying a scanned, projected
> map (but the projection is unknown)? Is it necessary to georectify the map
> first into a lat-long location and *then* r.proj the map into a target
> projection? This is the method I used, using 20 GCPs (reading lat-long
> graticule intersections from the map) and a cubic rectification, but there
> is still a lot of error (see attached; I overlaid the GSHHG coastline for
> comparison).
> I'm not sure if I am going about this the correct way.
I don't have too much experience with this, but I think it's a good
approach. But you also need to know the ellipsoid, not sure if that
could cause the misalignment.
Anna
> Thanks for any thoughts,
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
