[GRASS-user] Advice on georectification procedure
Eric Patton thepattonian at gmail.com
Fri May 13 07:14:20 PDT 2016
On Fri, May 13, 2016 at 10:48 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> >> I'm not sure if I am going about this the correct way.
> >I don't have too much experience with this, but I think it's a good
> >approach. But you also need to know the ellipsoid, not sure if that
> >could cause the misalignment.
> >Anna
Thanks, I have assumed WGS84, where the map was made in 2002; I'll also try
NAD27 as that is not uncommon in the region.
Eric
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160513/7b5461d8/attachment.html>
