[GRASS-user] Advice on georectification procedure
Stuart Edwards sedwards2 at cinci.rr.com
Fri May 13 07:51:05 PDT 2016
If you have a good coastline map, can you just geo-rectify the new map to it using coastline features as GCPs?  Then it'll have the same projection as the coastline layer and you can re-project it to your working projection.
Stu
> On May 13, 2016, at 10:14 AM, Eric Patton <thepattonian at gmail.com> wrote:
> On Fri, May 13, 2016 at 10:48 AM, Anna Petrášová <kratochanna at gmail.com <mailto:kratochanna at gmail.com>> wrote:
> >> I'm not sure if I am going about this the correct way.
> >I don't have too much experience with this, but I think it's a good
> >approach. But you also need to know the ellipsoid, not sure if that
> >could cause the misalignment.
> >Anna
> Thanks, I have assumed WGS84, where the map was made in 2002; I'll also try NAD27 as that is not uncommon in the region.
> Eric
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160513/a43a2812/attachment.html>
