[GRASS-user] FW: Temporal + export
Matías Alejandro Castillo Moine
matialecastillo at hotmail.com
Fri May 13 09:17:41 PDT 2016
Hi! I´m again!The problem whith galwarp is solved (spatial reference system was wrong). But now, I have my time serie registered in Grass and when I export it, I can only export this using the AAgrid or pack format, and R needs the GTiff formatt into the tar.gz archive. I believe that I´m using correctly the command
t.rast.export --overwrite input=LST2 at MOD11A2 output=MOD11A2.tar.gz directory=C:\SIG\Grass compression=gzipWARNING: El tipo de datos GDAL seleccionado no cubre el rango de datosWARNING: Tipo de datos GDAL: Byte, rango: 0 - 255WARNING: Rango a exportar: 14837 - 15732ERROR: La exportación raster puede resultar en una pérdida completa de datos, cancelando.Traceback (most recent call last): File "C:\OSGEO4~1\apps\grass\grass-7.0.4/scripts/t.rast.export.py", line 87, in <module> main() File "C:\OSGEO4~1\apps\grass\grass-7.0.4/scripts/t.rast.export.py", line 82, in main _input, output, compression, directory, where, _format,"strds") File "C:\OSGEO4~1\apps\grass\grass-7.0.4\etc\python\grass\temporal\stds_export.py", line 298, in export_stds rows, tar, list_file, new_cwd, fs, format_) File "C:\OSGEO4~1\apps\grass\grass-7.0.4\etc\python\grass\temporal\stds_export.py", line 97, in_export_raster_maps_as_gdal shutil.rmtree(new_cwd) File "C:\OSGEO4~1\apps\Python27\lib\shutil.py", line 252,in rmtree onerror(os.remove, fullname, sys.exc_info()) File "C:\OSGEO4~1\apps\Python27\lib\shutil.py", line 250,in rmtree os.remove(fullname)WindowsError: [Error 32] El proceso no tiene acceso alarchivo porque está siendo utilizado por otro proceso:'C:\\SIG\\Grass\\tmp883adw\\archive'(Fri May 13 13:09:21 2016) Comando finalizado. (2 segundos) (Fri May 13 13:14:02 2016)
Some new idea?
Thanks!!!
Date: Sat, 7 May 2016 14:09:33 +0200
Subject: Re: [GRASS-user] FW: Temporal + export
To: matialecastillo at hotmail.com
CC: veroandreo at gmail.com; grass-user at lists.osgeo.org
On May 6, 2016 11:24 PM, "Matías Alejandro Castillo Moine" <matialecastillo at hotmail.com> wrote:
> Hola Verooooo!
> Thanks you for answer!
> I'm working to solve it. Apparently all my imported rasters are zero cell values.
... maybe the data are there but the computational region wrong?
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160513/32d79fac/attachment.html>
