[GRASS-user] i.segment.stats memory usage error
    Markus Metz
    markus.metz.giswork at gmail.com
    Fri Nov  4 08:34:39 PDT 2016
On Fri, Nov 4, 2016 at 3:51 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 04/11/16 14:29, Markus Metz wrote:
>> On Wed, Nov 2, 2016 at 5:15 PM, Markus Metz
>> <markus.metz.giswork at gmail.com> wrote:
>>> On Wed, Nov 2, 2016 at 3:47 PM, Moritz Lennert
>>>> On 02/11/16 11:05, James Duffy wrote:
>>>>> I can't register with osgeo to submit a bug as no-one has replied with
>>>>> a
>>>>> 'mantra' for me to do so... what a convoluted bug reporting system!
>>>>> And in your opinion Moritz, does it look like my workflow will not be
>>>>> possible unless I find a 64bit machine with a decent amount of RAM?
>>>> I'm not sure about the necessity of 64bit, but more RAM probably.
>>>> IIUC, all the stats of all the zones are put into memory during the run
>>>> of
>>>> the module. Maybe a file-based store of the information might be
>>>> possible
>>>> which would avoid this memory usage, but I'm not sure.
>>>> @MarkusM: could you have a look at this ? See
>>>> https://lists.osgeo.org/pipermail/grass-user/2016-October/075493.html
>>>> for
>>>> the beginning of the thread. In short: James seems to be hitting memory
>>>> limits of r.univar and I'm wondering out loud whether there is something
>>>> that could be done about this...
>>> As Anna wrote, the -e flag increases memory consumption of r.univar
>>> considerably. A file based approach for extended stats of r.univar is
>>> difficult because the number of values per segment is initially
>>> unknown to r.univar, thus the amount of disk space needed for extended
>>> stats for each segment is unknown.
>>> I would rather use r.univar for standard stats and r.stats.quantile
>>> for extended stats.
>> There were some bugs in r.stats.quantile, fixed in r69770-2 in all G7
>> branches.
> Great, thanks !
>> About the limit to MAX_CATS categories in the base map (ticket #3198),
>> there is not really a reason for it. I guess it is meant to protect
>> against out-of-memory errors.
> Does this mean we can just take out the lines referencing it ?
Maybe replace the error with a warning. I tested with a base map with
1.4 million categories (output of i.segment) and it works, but I
needed to reduce the number of bins from 1000 to 100 to avoid OOM.
With a low number of bins, the memory consumption of r.stats.quantile
is much less than what r.univar requires, but a low number of bins can
in some cases (histogram of the cell values with a peak) lead to
higher memory consumption.
r.univar does memory reallocation on demand which means that for a
short time, double the amount of memory is needed. r.univar2 makes a
guess about how much memory is required and then allocates all at
once. Still, the binning approach of r.(stats.)quantile usually needs
less memory.
Markus M
