[GRASS-user] Problems removing/reinstalling Grass
    anna zanchetta
    ciupava at gmail.com
    Tue Nov  8 22:53:08 PST 2016
It seems like I've solved, I was just messing up with the compilation, so
false alarm.
I can't see the new addon in the available list (with g.extension -l), but
I can run it from command line.
Anna-with-Grass-again
On Mon, Nov 7, 2016 at 11:46 AM, anna zanchetta <ciupava at gmail.com> wrote:
> Hello community,
> I've been running a new addon that I wrote and added in my local folder of
> available add-ons, working in Ubuntu 64bit and compiling Grass from the
> current release version (7.0.x).
> Then decided to compile the trunk version, so when I got into Grass 73 I
> started having problems, namely g.extensions can't see my local list of
> available addons (not installed, just available).
> Basically I followed the intructions in the link [^] and repeated the
> steps  made with the release version (under the supervision of LucaDelu).
> Eventually I decided that there were too many Grass versions installed in
> my laptop (64 with package, 70 with release, 73 with svn) and thought that
> could make problems, so after some struggle with the pc I decided to get
> completely rid of Grass with the idea of reinstalling after a clean-up, and
> removed any version from my pc following the instructions here [*].
> After svn up, recompiling etc now the message I get from terminal when
> running grass (64, 70 or 73, no matter what) is the following:
> anna at anna-ubuntu:~$ grass73
> Cleaning up temporary files...
> Traceback (most recent call last):
>   File "/usr/local/bin/grass73", line 1971, in <module>
>     main()
>   File "/usr/local/bin/grass73", line 1852, in main
>     clean_temp()
>   File "/usr/local/bin/grass73", line 1591, in clean_temp
>     call([gpath("etc", "clean_temp")], stdout=nul)
>   File "/usr/local/bin/grass73", line 245, in call
>     return subprocess.call(cmd, **kwargs)
>   File "/usr/lib/python2.7/subprocess.py", line 522, in call
>     return Popen(*popenargs, **kwargs).wait()
>   File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
>     errread, errwrite)
>   File "/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child
>     raise child_exception
> OSError: [Errno 2] No such file or directory
> not much fun, from bad to worse :)
> Can someone help me to find how to solve this?
> And maybe to run my new addon?
> Thanks!
> Anna-without-Grass
> https://grasswiki.osgeo.org/wiki/Compile_and_Install#Addons
> https://grasswiki.osgeo.org/wiki/Compile_and_Install_
> Ubuntu#Removal_of_GRASS
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161109/07f49aa4/attachment.html>
