[GRASS-user] new map in wxgui digitizer
    Dave Roberts
    droberts at montana.edu
    Fri Nov 18 14:10:28 PST 2016
Hi Anna,  yes I can create tickets now.  I'll do that this weekend.
Thanks, Dave
On 11/18/16 10:03, Anna Petrášová wrote:
> On Fri, Nov 18, 2016 at 10:41 AM, Dave Roberts <droberts at montana.edu> wrote:
>> Friends,
>>   I am trying to make use of the wxgui digitizer and finding it somewhat
>> challenging.  One issue is that I like to run from the console (i.e. grass73
>> -text) and that produces a subtly different widget than if I run from the
>> gui (i.e. grass73 -gui).  Using the console version, when I try to digitize
>> a new map (as opposed to editing an existing map) I get the error below.
>> GRASS GIS 7.3.svn > Traceback (most recent call last):
>>   File "/usr/local/grass-7.3.svn/gui/wxpython/vdigit/toolbars.py", line 849,
>> in OnSelectMap
>>     if self.layers[selection] == self.mapLayer:
>> UnboundLocalError: local variable 'selection' referenced before assignment
>> and it doesn't digitize any points.
>> The obvious short term solution is to work from the GUI, but that defeats
>> much oswhat I am trying to accomplish in scriptable, repeatable analyses.
>> GRASS GIS 7.3.svn (r69510)
>> Linux luthertucker 4.8.7-1-ARCH #1 SMP PREEMPT Thu Nov 10 17:22:48 CET 2016
>> x86_
>> Thanks, Dave
> That's a bug we should fix before release (if it's in 72). I don't
> remember, are you able to create a ticket now?
> Anna
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
