[GRASS-user] new map in wxgui digitizer
Anna Petrášová
kratochanna at gmail.com
Fri Nov 18 09:03:30 PST 2016
On Fri, Nov 18, 2016 at 10:41 AM, Dave Roberts <droberts at montana.edu> wrote:
> Friends,
> I am trying to make use of the wxgui digitizer and finding it somewhat
> challenging. One issue is that I like to run from the console (i.e. grass73
> -text) and that produces a subtly different widget than if I run from the
> gui (i.e. grass73 -gui). Using the console version, when I try to digitize
> a new map (as opposed to editing an existing map) I get the error below.
> GRASS GIS 7.3.svn > Traceback (most recent call last):
> File "/usr/local/grass-7.3.svn/gui/wxpython/vdigit/toolbars.py", line 849,
> in OnSelectMap
> if self.layers[selection] == self.mapLayer:
> UnboundLocalError: local variable 'selection' referenced before assignment
> and it doesn't digitize any points.
> The obvious short term solution is to work from the GUI, but that defeats
> much oswhat I am trying to accomplish in scriptable, repeatable analyses.
> GRASS GIS 7.3.svn (r69510)
> Linux luthertucker 4.8.7-1-ARCH #1 SMP PREEMPT Thu Nov 10 17:22:48 CET 2016
> x86_
> Thanks, Dave
That's a bug we should fix before release (if it's in 72). I don't
remember, are you able to create a ticket now?
Anna
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
