[GRASS-user] areas with no centroid
Helmut Kudrnovsky hellik at web.de
Sun Nov 27 12:24:16 PST 2016
Dave Roberts wrote
> After editing a map with wxgui I ended up with 39 areas and 38
> centroids.  How do I find and delete the area with no centroid?
> I have tried many combinations of v.info, v.category, v.to.db, and
> visualizing with d.vect.  If I use v.clean tool=rmarea with slowly
> increasing thresholds it gets rid of an area I want before it finds the
> one I don't so I don't think it's a sliver.
> GRASS GIS 7.3.svn > v.info demo
> Number of points:       0           Number of centroids: 38
> Number of lines:        0           Number of boundaries: 112
> Number of areas:       39           Number of islands:    19
> GRASS GIS 7.3.svn > v.category demo op=report
> Layer/table: 1/demo
> type       count        min        max
> point          0          0          0
> line           0          0          0
> boundary       0          0          0
> centroid      38          1         75
> area           0          0          0
> face           0          0          0
> kernel         0          0          0
> all           38          1         75
> Thanks, Dave
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
d. vect has following option :
cat: Display category numbers of features
try to display the cat info for the polygones to check where the centroid is
missing.
have then a look at v.extract and extract only these polygones you need.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/areas-with-no-centroid-tp5297590p5297591.html
Sent from the Grass - Users mailing list archive at Nabble.com.
