[GRASS-user] Dissolve polygones from layer1 witch intersect with polygones of layer2
Mounirsky kaizersozy at gmail.com
Mon Nov 28 06:37:13 PST 2016
I want to dissolve polygons from layer1 witch overlap with polygons of layer2
keeping attributes table of layer1 and using command line.
What I've done :
v.in.ogr -o input=original_plygons output=layer1
v.in.ogr -o input=plygons_to_add output=layer2
v.patch -a input=layer2 output=layer1
(v.dissolve input=layer1 output=dissolved column=??? )
the problem is to dissolve you should chose a column ! and after the patch
(merge) the overlapping polygons of layer2 doesn't have a common same value
to dissolve them correctly...
Can you please help me to solve this problem ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Dissolve-polygones-from-layer1-witch-intersect-with-polygones-of-layer2-tp5297681.html
Sent from the Grass - Users mailing list archive at Nabble.com.
