[GRASS-user] Dissolve polygones from layer1 witch intersect with polygones of layer2
    Markus Metz
    markus.metz.giswork at gmail.com
    Tue Nov 29 05:53:48 PST 2016
On Mon, Nov 28, 2016 at 3:37 PM, Mounirsky <kaizersozy at gmail.com> wrote:
> I want to dissolve polygons from layer1 witch overlap with polygons of
layer2
> keeping attributes table of layer1 and using command line.
> What I've done :
> v.in.ogr -o input=original_plygons output=layer1
> v.in.ogr -o input=plygons_to_add output=layer2
> v.patch -a input=layer2 output=layer1
> (v.dissolve input=layer1 output=dissolved column=??? )
> the problem is to dissolve you should chose a column ! and after the patch
> (merge) the overlapping polygons of layer2 doesn't have a common same
value
> to dissolve them correctly...
> Can you please help me to solve this problem ?
You could use v.select to select those polygons from vector 1 that overlap
with polygons from vector 2, the dissolve the selected polygons.
Markus M
http://osgeo-org.1560.x6.nabble.com/Dissolve-polygones-from-layer1-witch-intersect-with-polygones-of-layer2-tp5297681.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161129/24c88c02/attachment.html>
