[GRASS-user] map display query and layers
Dave Roberts
droberts at montana.edu
Sun Oct 2 09:53:14 PDT 2016
Thanks Helmut,
On 10/02/16 02:53, Helmut Kudrnovsky wrote:
{material deleted for space ...}
> it seems that d.what.vect [1] reports always all data of all layers.
> the same with v.what although the queried layer is specified.
> so maybe a bug/enhancement ticket is needed.
> [1] https://grass.osgeo.org/grass73/manuals/d.what.vect.html
> [2] https://grass.osgeo.org/grass73/manuals/v.what.html
Just to be clear, in my case the problem was not that d.what.vect listed
ALL the layers (that would have been OK although excessively verbose),
but rather from click to click I might get different layers reported,
and even different numbers of layers reported. Generally the one I
wanted wasn't included or I would have ignored the problem.
Moritz has proposed a fix to the issue you noted, and it looks like it
will likely solve my problem as well. That may take a while to find out
though.
Thanks, Dave
