[GRASS-user] map display query and layers
Helmut Kudrnovsky
hellik at web.de
Sun Oct 2 13:27:31 PDT 2016
Dave Roberts wrote
> Thanks Helmut,
> On 10/02/16 02:53, Helmut Kudrnovsky wrote:
> {material deleted for space ...}
>> it seems that d.what.vect [1] reports always all data of all layers.
>> the same with v.what although the queried layer is specified.
>> so maybe a bug/enhancement ticket is needed.
>> [1] https://grass.osgeo.org/grass73/manuals/d.what.vect.html
>> [2] https://grass.osgeo.org/grass73/manuals/v.what.html
> Just to be clear, in my case the problem was not that d.what.vect listed
> ALL the layers (that would have been OK although excessively verbose),
> but rather from click to click I might get different layers reported,
> and even different numbers of layers reported. Generally the one I
> wanted wasn't included or I would have ignored the problem.
> Moritz has proposed a fix to the issue you noted, and it looks like it
> will likely solve my problem as well. That may take a while to find out
> though.
> Thanks, Dave
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
Are all vector geometries of your data available in all layers?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5288958.html
Sent from the Grass - Users mailing list archive at Nabble.com.
