[GRASS-user] r.water.outlet: no map displayed
Helmut Kudrnovsky hellik at web.de
Mon Oct 3 11:24:51 PDT 2016
Rich Shepard wrote
> On Mon, 3 Oct 2016, Markus Neteler wrote:
>>> nsres:      1.00019858
>>> ewres:      1.00059954
>> ^-- you have no-square pixels, is that on purpose? Of course that's
>> supported but just to reduce the amount of error if undesired.
> Markus,
>    Nope. That's the result of re-projecting from
> NAD_1983_HARN_StatePlane_Oregon_North_FIPS_3601_Feet_Intl (EPSG 2992) to
> NAD83(HARN) / Oregon North (EPSG 2838). I saw the discrepancy but assumed
> GRASS knew what it was doing.
>    I can see how that could cause the problem.
I've got the data offline, and tested locally
findings with the coordinates taken from the thread:
r.watershed elevation=outraster at data drainage=draindir
r.water.outlet input=draindir at data output=basin
coordinates=2295821.27858,175258.094514
to see the r.water.outlet results, just do
r.to.vect input=basin output=vbasin
the result is just 1 pixel, as already earlier mentioned in the thread,
because the coordinates=2295821.27858,175258.094514 aren't a outlet point.
easy to check by e.g.
r.stream.extract elevation=outraster at data accumulation=accum at data
threshold=10 d8cut=1000000000000 stream_raster=runiqe stream_vector=vunique
then v.in.ascii 2295821.27858,175258.094514, and overlay the extracted
streams and the v.in.ascii-vector
randomly tested
r.water.outlet --verbose input=draindir at data output=basin2
2295824.16407,175258.754074 (which is on the stream network by
<http://osgeo-org.1560.x6.nabble.com/file/n5289100/check.png>  ru
the solution may be, find a outlet point which is on the stream network
which is appropriate for your analysis and then run r.water.outlet.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-water-outlet-no-map-displayed-tp5288967p5289100.html
Sent from the Grass - Users mailing list archive at Nabble.com.
