[GRASS-user] map display query and layers
Helmut Kudrnovsky hellik at web.de
Tue Oct 4 05:32:47 PDT 2016
Dave Roberts wrote
> Thanks Helmut, Thanks Anna
> I compiled the trunk version, and the map query tool now clearly behaves
> differently, but not how I expected
> 1) it shows all layers in the map query results, regardless of what
> layer (if any) was selected in d.vect
> I.e.
> d.vect map
> d.vect map layer=1
> v.vect map layer=2
> all have identical results in map query.  In addition, specifying layers
> that don't exist emits no warning, e.g. d.vect map layer=999
> works fine, and behaves the same as any of the d.vect commands above
> 2) it highlights selected features in yellow, and the selected features
> (areas in my case) reflect layer #1, no matter what layer is requested
> in d.vect.  I.e. d.vect map layer=2 map queries highlight layer 1.
> I had been working on this with a quite complicated imported data set,
> so to isolate the behavior more clearly I created the data below
> (file ascii.txt)
> VERTI:
> B 5
>   0  0
>   0 10
> 10 10
> 10  0
>   0  0
> C 1 1
>   8  5
>   1  1
> B 5
> 10  0
> 10 10
> 20 10
> 20  0
> 10  0
> C 1 1
> 18  5
>    1 2
> B 5
>   3  3
>   3  7
>   7  7
>   7  3
>   3  3
> C 1 1
>   5  5
>   1  2
> B 5
> 13  3
> 13  7
> 17  7
> 17  3
> 13  3
> C 1 1
> 15  5
>   1  1
> (end of file)
> then
> v.in.ascii input=ascii.txt output=ascii format=standard
> g.region vect=ascii
> v.category --overwrite option=add input=ascii output=new_ascii
>      layer=2 type=centroid
> # check results
> v.category ascii op=report
> # 1 layer, 4 centroids with cats 1 & 2
> v.category new_ascii op=report
> # 2 layers, L1 4 centroids with cats 1,2 L2 4 centroids cats=1,2,3,4
> d.vect new_ascii layer=2
> # and check results with map query tool
> Thanks, Dave
> On 10/04/16 01:31, Helmut Kudrnovsky wrote:
>>   >At any rate, since I did not edit what.c to apply Moritz's patch
>>> none of this affects my issues with map display query or >d.what.vect.
>>> I'll get back to that in a subsequent post.
>> Fyi
>> http://lists.osgeo.org/pipermail/grass-commit/2016-
>> October/040536.html
>> Anna committed the patch to trunk ; so if may be able to switch to trunk
>> for
>> compiling, this v.what addition is available there without the need of
>> manually patching.
>> best regards
>> Helmut
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5289152.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
> grass-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/grass-user
AFAIK the map query hasn't been changed by Anna's commit.
v. what (https://grass.osgeo.org/grass73/manuals/v.what.html) has a changed
behaviour by now reckognizing the specified layer.
the same behaviour for the map query may need a separate enhancement ticket.
in the meantime would be v.what an alternative?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/map-display-query-and-layers-tp5288830p5289199.html
