[GRASS-user] ps.map vlegend name
Conrad Bielski
conrad_bielski at yahoo.com
Thu Oct 6 00:38:46 PDT 2016
Thanks Nikos,I'm sure that's the solution (will test today). But the docs don't describe the 'label' parameter in the vlegend section. That's probably why I didn't notice it...
Otherwise, the docs are great!
Have a great day,Conrad
From: Nikos Alexandris <nik at nikosalexandris.net>
To: Conrad Bielski <conrad_bielski at yahoo.com>
Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
Sent: Wednesday, October 5, 2016 11:44 PM
Subject: Re: [GRASS-user] ps.map vlegend name
Conrad Bielski:
>Hi,
Hi Conrad,
> I looked around but couldn't find the answer to my particular problem. I'm generating PS maps using the ps.map functionality and use the vlegend to add a legend. However, each layer name also includes PERMANENT. How can I remove this from the name?
>For example, my layer name is roads but when the legend if produced, it prints: roads (PERMANENT).
>I presume it's because the vectors were saved in PERMANENT, but how can I remove it from the legend when producing my PS map?
>Thanks in advance and have a great day,Conrad
Did you check for the `label`? From the manual
(https://grass.osgeo.org/grass70/manuals/ps.map.html#vlegend):
label - for description in vlegend. Default is: map(mapset);
Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161006/440d05e9/attachment.html>
