[GRASS-user] ps.map vlegend name
Nikos Alexandris nik at nikosalexandris.net
Wed Oct 5 15:44:33 PDT 2016
Conrad Bielski:
>Hi,
Hi Conrad,
> I looked around but couldn't find the answer to my particular problem. I'm generating PS maps using the ps.map functionality and use the vlegend to add a legend. However, each layer name also includes PERMANENT. How can I remove this from the name?
>For example, my layer name is roads but when the legend if produced, it prints: roads (PERMANENT).
>I presume it's because the vectors were saved in PERMANENT, but how can I remove it from the legend when producing my PS map?
>Thanks in advance and have a great day,Conrad
Did you check for the `label`?  From the manual
(https://grass.osgeo.org/grass70/manuals/ps.map.html#vlegend):
label - for description in vlegend. Default is: map(mapset);
Nikos
