[GRASS-user] Problem in running r.basin
    Priscilla_I
    isacco.silvia at gmail.com
    Thu Oct 13 07:51:39 PDT 2016
I'm a new grass user, running "r.basin" module for Grass 7.0.4 on Windows
10, I get this error message "ERROR: Region resolution and raster map
<out_Ghiandone_DEM_strahler> resolution differs. Run 'g.region
raster=out_Ghiandone_DEM_strahler' to set proper region resolution."
I'm using a map in projected coordinates, and I align region with the raster
g.region -p -a raster=out_Ghiandone_DEM_strahler at Silvia
align=out_Ghiandone_DEM_strahler at Silvia
projection: 1 (UTM)
zone:       32
datum:      wgs84
ellipsoid:  wgs84
north:      4965768.6398801
south:      4943886.74090327
west:       353479.72655961
east:       379279.66825865
nsres:      24.64177813
ewres:      24.64177813
rows:       888
cols:       1047
cells:      929736
raster info are
Map:      out_Ghiandone_DEM_strahler at Si  Date: Thu Oct 13 11:31:23 2016    |
 | Mapset:   Silvia                         Login of Creator: Silvia
 | DataBase: C:\Users\Silvia\Desktop\Grass
 | Title:     ( out_Ghiandone_DEM_strahler )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    CELL
 |   Rows:         888
 |   Columns:      1047
 |   Total Cells:  929736
 |        Projection: UTM (zone 32)
 |            N: 4965768.6398801    S: 4943886.74090327   Res: 24.64177813
 |            E: 379279.66825865    W: 353479.72655961   Res: 24.64177813
 |   Range of data:    min = 1  max = 4
 |   Data Description:
 |    generato da r.stream.order
 |   Comments:
 |    r.stream.order stream_rast="out_Ghiandone_DEM_stream_e" direction="o\
 |    ut_Ghiandone_DEM_drainage_e" strahler="out_Ghiandone_DEM_strahler" h\
 |    orton="out_Ghiandone_DEM_horton" shreve="out_Ghiandone_DEM_shreve" h\
 |    ack="out_Ghiandone_DEM_hack" memory=300
Any ideas? Thanks in advance!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587.html
Sent from the Grass - Users mailing list archive at Nabble.com.
