[GRASS-user] Problem in running r.basin
Margherita Di Leo diregola at gmail.com
Thu Oct 13 09:18:17 PDT 2016
On Thu, Oct 13, 2016 at 4:51 PM, Priscilla_I <isacco.silvia at gmail.com>
wrote:
> Hi,
> I'm a new grass user, running "r.basin" module for Grass 7.0.4 on Windows
> 10, I get this error message "ERROR: Region resolution and raster map
> <out_Ghiandone_DEM_strahler> resolution differs. Run 'g.region
> raster=out_Ghiandone_DEM_strahler' to set proper region resolution."
> I'm using a map in projected coordinates, and I align region with the
> raster
> g.region -p -a raster=out_Ghiandone_DEM_strahler at Silvia
> align=out_Ghiandone_DEM_strahler at Silvia
> projection: 1 (UTM)
> zone:       32
> datum:      wgs84
> ellipsoid:  wgs84
> north:      4965768.6398801
> south:      4943886.74090327
> west:       353479.72655961
> east:       379279.66825865
> nsres:      24.64177813
> ewres:      24.64177813
> rows:       888
> cols:       1047
> cells:      929736
> raster info are
> Map:      out_Ghiandone_DEM_strahler at Si  Date: Thu Oct 13 11:31:23 2016
>  | Mapset:   Silvia                         Login of Creator: Silvia
>  | Location: Piemonte
>  | DataBase: C:\Users\Silvia\Desktop\Grass
>  | Title:     ( out_Ghiandone_DEM_strahler )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 0
>  |   Data Type:    CELL
>  |   Rows:         888
>  |   Columns:      1047
>  |   Total Cells:  929736
>  |        Projection: UTM (zone 32)
>  |            N: 4965768.6398801    S: 4943886.74090327   Res: 24.64177813
>  |            E: 379279.66825865    W: 353479.72655961   Res: 24.64177813
>  |   Range of data:    min = 1  max = 4
>  |   Data Description:
>  |    generato da r.stream.order
>  |   Comments:
>  |    r.stream.order stream_rast="out_Ghiandone_DEM_stream_e"
> direction="o\
>  |    ut_Ghiandone_DEM_drainage_e" strahler="out_Ghiandone_DEM_strahler"
> h\
>  |    orton="out_Ghiandone_DEM_horton" shreve="out_Ghiandone_DEM_shreve"
> h\
>  |    ack="out_Ghiandone_DEM_hack" memory=300
> Any ideas? Thanks in advance!
What is the exact r.basin command line that you  run? Can you post also
r.info of the DEM that you use as input?
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161013/f0472f73/attachment-0001.html>
