[GRASS-user] Interpreting r.watershed accumulation map
Rich Shepard rshepard at appl-ecosys.com
Fri Oct 14 18:15:13 PDT 2016
On Sat, 15 Oct 2016, Sören Gebbert wrote:
> Please try to put all mapsets that you use in your analysis into the
> mapset search path. The temporal framework will only access strds in
> mapsets that are located in the current search path.
Soeren,
   I use g.mapsets to add all 5 mapsets to the search path. Regardless,
tomorrow I'll make sure they're all in the search path and run Itzi again.
Many thanks,
Rich
