[GRASS-user] Interpreting r.watershed accumulation map
Rich Shepard
rshepard at appl-ecosys.com
Sun Oct 16 13:03:32 PDT 2016
On Sat, 15 Oct 2016, Sören Gebbert wrote:
> Please try to put all mapsets that you use in your analysis into the
> mapset search path. The temporal framework will only access strds in
> mapsets that are located in the current search path.
Soeren,
Current mapset is 'analyses':
> g.mapset -p
analyses
Some maps might be in other mapsets so ...
> g.mapsets -p
Accessible mapsets:
analyses PERMANENT features soils topography precipitation
which is all the mapsets in the location.
The file, itzi-param.txt, contains:
[time]
duration = 2:00:00
record_step = 00:05:00
[input]
dem = be_cropped at topography
friction = n
rain = rain
[output]
prefix = pop
values = h, wse, v, vdir, boundaries
[statistics]
stats_file = pop.csv
And this is the traceback:
> itzi run itzi-param.txt
Starting simulation of itzi-param.txt...
WARNING: Error during execution: Traceback (most recent call last):
File "/usr/lib/python2.7/site-packages/itzi/itzi.py", line 183, in
sim_runner_worker
sim_runner.run()
File "/usr/lib/python2.7/site-packages/itzi/itzi.py", line 90, in run
sim_param=self.conf.sim_param)
File "/usr/lib/python2.7/site-packages/itzi/simulation.py", line 77, in
__init__
self.gis.read(self.in_map_names)
File "/usr/lib/python2.7/site-packages/itzi/gis.py", line 187, in read
elif self.name_is_stds(self.format_id(map_name)):
File "/usr/lib/python2.7/site-packages/itzi/gis.py", line 138, in
name_is_stds
if tgis.SpaceTimeRasterDataset(name).is_in_db():
File
"/usr/local/grass-7.3.svn/etc/python/grass/temporal/abstract_dataset.py",
line 368, in is_in_db
return self.base.is_in_db(dbif)
File "/usr/local/grass-7.3.svn/etc/python/grass/temporal/base.py", line
315, in is_in_db
dbif.execute(sql, mapset=self.mapset)
File "/usr/local/grass-7.3.svn/etc/python/grass/temporal/core.py", line
981, in execute
self._create_mapset_error_message(mapset)))
File
"/usr/local/grass-7.3.svn/etc/python/grass/pygrass/messages/__init__.py",
line 271, in fatal
sys.exit(1)
SystemExit: 1
Simulations complete. Elapsed times:
itzi-param.txt: 0:00:01
Total: 0:00:01
Average: 0:00:01
Please suggest what I should try modifying.
Thanks,
Rich
