[GRASS-user] Interpreting r.watershed accumulation map
Rich Shepard
rshepard at appl-ecosys.com
Sun Oct 16 14:49:43 PDT 2016
On Sun, 16 Oct 2016, Sören Gebbert wrote:
> I don't know why this happens. It may be a bug in the temporal framework
> or in itzi. Testing the code in the temporal framework seems to work, but
> more testing is needed.
Soren,
If I can help test with my data I'll be happy to contribute to getting
this tool working.
> However, the traceback is fine, but there must be an error message that
> will tell you what mapset is missing and what mapsets are in the temporal
> framework search path.
> Something like:
> You have no permission to "
> "access mapset <%(mapset)s>, or "
> "mapset <%(mapset)s> has no temporal database. "
> "Accessable mapsets are: <%(mapsets)s>
I sent everything displayed on the console from the command line to the
end. The mapset may not have a temporal database, however ... the mapset's
subdirectory in the location contains two subdirectories: g3dcell and tgis.
g3dcell/ is empty and tgis/ conains 'sqlite.db' holding 462848 bytes:
sqlite> .tables
raster3d_absolute_time str3ds_absolute_time stvds_metadata
raster3d_base str3ds_base stvds_relative_time
raster3d_metadata str3ds_metadata stvds_spatial_extent
raster3d_relative_time str3ds_relative_time stvds_view_abs_time
raster3d_spatial_extent str3ds_spatial_extent stvds_view_rel_time
raster3d_stds_register str3ds_view_abs_time tgis_metadata
raster3d_view_abs_time str3ds_view_rel_time vector_absolute_time
raster3d_view_rel_time strds_absolute_time vector_base
raster_absolute_time strds_base vector_metadata
raster_base strds_metadata vector_relative_time
raster_metadata strds_relative_time vector_spatial_extent
raster_relative_time strds_spatial_extent vector_stds_register
raster_spatial_extent strds_view_abs_time vector_view_abs_time
raster_stds_register strds_view_rel_time vector_view_rel_time
raster_view_abs_time stvds_absolute_time
raster_view_rel_time stvds_base
The schema's too large to print here.
Does any of this help?
Rich
