[GRASS-user] Interpreting r.watershed accumulation map
Laurent C.
lrntct at gmail.com
Mon Oct 17 10:31:04 PDT 2016
Hello Sören,
The problem occurs when Itzï is calling:
"tgis.SpaceTimeRasterDataset(name).is_in_db()"
tgis.init() is called just before. "name" is a a formatted map or
strds ID (i.e including mapset)
It is difficult to understand what is happening because I can't
reproduce the problem.
Regards,
Laurent
2016-10-16 16:01 GMT-05:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi,
> i don't know why this happens. It may be a bug in the temporal framework or
> in itzi. Testing the code in the temporal framework seems to work, but more
> testing is needed.
> However, the traceback is fine, but there must be an error message that will
> tell you what mapset is missing and what mapsets are in the temporal
> framework search path.
> Something like:
> You have no permission to "
> "access mapset <%(mapset)s>, or "
> "mapset <%(mapset)s> has no temporal database. "
> "Accessable mapsets are: <%(mapsets)s>
> Best regards
> Soeren
> 2016-10-16 22:03 GMT+02:00 Rich Shepard <rshepard at appl-ecosys.com>:
>> On Sat, 15 Oct 2016, Sören Gebbert wrote:
>>> Please try to put all mapsets that you use in your analysis into the
>>> mapset search path. The temporal framework will only access strds in
>>> mapsets that are located in the current search path.
>> Soeren,
>> Current mapset is 'analyses':
>>> g.mapset -p
>> analyses
>> Some maps might be in other mapsets so ...
>>> g.mapsets -p
>> Accessible mapsets:
>> analyses PERMANENT features soils topography precipitation
>> which is all the mapsets in the location.
>> The file, itzi-param.txt, contains:
>> [time]
>> duration = 2:00:00
>> record_step = 00:05:00
>> [input]
>> dem = be_cropped at topography
>> friction = n
>> rain = rain
>> [output]
>> prefix = pop
>> values = h, wse, v, vdir, boundaries
>> [statistics]
>> stats_file = pop.csv
>> And this is the traceback:
>>> itzi run itzi-param.txt
>> Starting simulation of itzi-param.txt... WARNING: Error during execution:
>> Traceback (most recent call last):
>> File "/usr/lib/python2.7/site-packages/itzi/itzi.py", line 183, in
>> sim_runner_worker
>> sim_runner.run()
>> File "/usr/lib/python2.7/site-packages/itzi/itzi.py", line 90, in run
>> sim_param=self.conf.sim_param)
>> File "/usr/lib/python2.7/site-packages/itzi/simulation.py", line 77, in
>> __init__
>> self.gis.read(self.in_map_names)
>> File "/usr/lib/python2.7/site-packages/itzi/gis.py", line 187, in read
>> elif self.name_is_stds(self.format_id(map_name)):
>> File "/usr/lib/python2.7/site-packages/itzi/gis.py", line 138, in
>> name_is_stds
>> if tgis.SpaceTimeRasterDataset(name).is_in_db():
>> File
>> "/usr/local/grass-7.3.svn/etc/python/grass/temporal/abstract_dataset.py",
>> line 368, in is_in_db
>> return self.base.is_in_db(dbif)
>> File "/usr/local/grass-7.3.svn/etc/python/grass/temporal/base.py", line
>> 315, in is_in_db
>> dbif.execute(sql, mapset=self.mapset)
>> File "/usr/local/grass-7.3.svn/etc/python/grass/temporal/core.py", line
>> 981, in execute
>> self._create_mapset_error_message(mapset)))
>> File
>> "/usr/local/grass-7.3.svn/etc/python/grass/pygrass/messages/__init__.py",
>> line 271, in fatal
>> sys.exit(1)
>> SystemExit: 1
>> Simulations complete. Elapsed times: itzi-param.txt: 0:00:01 Total:
>> 0:00:01 Average: 0:00:01
>> Please suggest what I should try modifying.
>> Thanks,
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
