[GRASS-user] Problem running i.segment.stats
James Duffy
james.philip.duffy at gmail.com
Tue Oct 18 08:44:36 PDT 2016
On 18 October 2016 at 16:37, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 18/10/16 17:28, James Duffy wrote:
>> On 18 October 2016 at 16:17, Moritz Lennert
>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>> wrote:
>> On 18/10/16 14:27, James Duffy wrote:
>> Hello,
>> I'm using GRASS 7.0.4 on the OSGeoLive pre-built operating
>> system. I
>> have installed the addon 'i.segment.stats' to use with my output
>> from
>> 'i.segment.uspo'.
>> When selecting the 'rasters' input for this tool, I choose the
>> original
>> layers that were used to create the segmented map in the first
>> place.
>> Upon execution of 'i.segment.stats', i get the following error:
>> Element type should be "cell" and not "raster.
>> The above message is just a warning and should not keep the module
>> from working. I just fixed this (r69700), so try reinstalling
>> i.segment.stats.
>> Ok thank you, have reinstalled and the message no longer appears.
>> The tool does not continue and outputs a blank .csv file.
>> Any help solving this would be much appreciated.
>> Could you send us the command line used (you can get that by pushing
>> the 'Copy' button in the GUI of the module or through the command
>> history in the GUI 'command console')
>> i.segment.stats --overwrite --verbose
>> map=angle_seg_uspo_angle_region_1_rank1 at angle1
>> rasters=angle_ortho.1 at angle1 raster_statistics=min,max,mean,stddev,sum
>> csvfile=/home/jd/Wales_GRASS/isegstats_gp_test separator=comma
>> With this command, the output .csv is still empty apart from the headers.
> Are you sure the region is set to angle_seg_uspo_angle_region_1_rank1 ?
> I.e.:
> g.region rast=angle_seg_uspo_angle_region_1_rank1
This fixed it. Sorry, I assumed that the region was already set to the
rasters that were used to create the segmented map (which are identical in
extent to the segmented map itself). Will make a note in my script to
always set the region to the input for i.segment.stats.
> What do
> g.region -p
> and
> r.info angle_seg_uspo_angle_region_1_rank1
> give you ?
Thanks for your help Moritz!
> Moritz
James
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161018/947c257a/attachment.html>
