[GRASS-user] Problem running i.segment.stats
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 18 08:37:02 PDT 2016
On 18/10/16 17:28, James Duffy wrote:
> On 18 October 2016 at 16:17, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> On 18/10/16 14:27, James Duffy wrote:
> Hello,
> I'm using GRASS 7.0.4 on the OSGeoLive pre-built operating system. I
> have installed the addon 'i.segment.stats' to use with my output
> from
> 'i.segment.uspo'.
> When selecting the 'rasters' input for this tool, I choose the
> original
> layers that were used to create the segmented map in the first
> place.
> Upon execution of 'i.segment.stats', i get the following error:
> Element type should be "cell" and not "raster.
> The above message is just a warning and should not keep the module
> from working. I just fixed this (r69700), so try reinstalling
> i.segment.stats.
> Ok thank you, have reinstalled and the message no longer appears.
> The tool does not continue and outputs a blank .csv file.
> Any help solving this would be much appreciated.
> Could you send us the command line used (you can get that by pushing
> the 'Copy' button in the GUI of the module or through the command
> history in the GUI 'command console')
> i.segment.stats --overwrite --verbose
> map=angle_seg_uspo_angle_region_1_rank1 at angle1
> rasters=angle_ortho.1 at angle1 raster_statistics=min,max,mean,stddev,sum
> csvfile=/home/jd/Wales_GRASS/isegstats_gp_test separator=comma
> With this command, the output .csv is still empty apart from the headers.
Are you sure the region is set to angle_seg_uspo_angle_region_1_rank1 ?
I.e.:
g.region rast=angle_seg_uspo_angle_region_1_rank1
What do
g.region -p
and
r.info angle_seg_uspo_angle_region_1_rank1
give you ?
Moritz
