[GRASS-user] v.to.rast error in version 7.0.6svn
alassane toure
atourej at gmail.com
Tue Oct 18 20:21:39 PDT 2016
Anna,
is that the command needed to make the connection? ...
db.connect driver=sqlite
database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
db.tables -p
v.db.connect map=vectormap table=table driver=sqlite \
v.db.connect -p map=vectormap
Thanks,
Alassane
On Tue, Oct 18, 2016 at 9:46 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, Oct 18, 2016 at 9:31 PM, alassane toure <atourej at gmail.com> wrote:
>> Group,
>> While executing v.to.rast the following error came up (not present in
>> earlier 7.0 version)
>> Your suggestion is appreciated.
> Check your database connection for the input vector, it says:
> "Database connection not defined for layer <1>"
> using v.db.connect -p vector_name
> Anna
>> Thanks
>> Alassane
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161018/dbb8fa9d/attachment.html>
