[GRASS-user] v.to.rast error in version 7.0.6svn
Anna Petrášová kratochanna at gmail.com
Tue Oct 18 20:29:39 PDT 2016
On Tue, Oct 18, 2016 at 11:21 PM, alassane toure <atourej at gmail.com> wrote:
> Anna,
> is that the command needed to make the connection? ...
No, it just shows you the current connection, I was just trying to
analyze the problem.
> db.connect driver=sqlite
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
> db.tables -p
> v.db.connect map=vectormap table=table driver=sqlite \
> v.db.connect -p map=vectormap
> Thanks,
> Alassane
> On Tue, Oct 18, 2016 at 9:46 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Tue, Oct 18, 2016 at 9:31 PM, alassane toure <atourej at gmail.com> wrote:
>>> Group,
>>> While executing v.to.rast the following error came up (not present in
>>> earlier 7.0 version)
>>> Your suggestion is appreciated.
>> Check your database connection for the input vector, it says:
>>  "Database connection not defined for layer <1>"
>> using v.db.connect -p vector_name
>> Anna
>>> Thanks
>>> Alassane
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
