[GRASS-user] DBMI-SQLite drive error when running i.segment.stats (with vector map creation)
Helmut Kudrnovsky
hellik at web.de
Wed Oct 19 01:48:10 PDT 2016
James Duffy wrote
> I think that you're correct.
> v.db.addcolumn --verbose map=angle_region_1_poly at angle1 columns=test.test
> gives:
> Adding column
> <test.test>
> to the table
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> near ".": syntax error
> ERROR: Error while executing: 'ALTER TABLE angle_region_1_poly ADD COLUMN
> test.test'
> ERROR: Unable to add column
> <test.test>
> Given that the default output names created when multi band rasters are
> read into GRASS with r.in.gdal contain a '.', and that these names can
> sometimes be used for labeling in vector operations (as I have
> described)...Is this something that can be rectified in the code of tools,
> or just something that should be worked around by the person using the
> tools?
> I guess I could do this with a g.rename.
> Thanks
> James
> On 18 October 2016 at 17:51, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> >angle_ortho.1_min double precision
>> I suspect that it is the point in the column name.
>> to verify, try to add such a column name in one of your vectors.
>> best regards
>> Helmut
>> View this message in context: http://osgeo-org.1560.x6.
>> nabble.com/DBMI-SQLite-drive-error-when-running-i-segment-
>> stats-with-vector-map-creation-tp5291318p5291319.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
> grass-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> *James Duffy*
> PhD Researcher
> Environment and Sustainability Institute
> Penryn Campus
> University of Exeter
> Penryn
> Cornwall
> TR10 9FE
maybe open an enhancement ticket in track to add new separators for
multiband import in r.in.gdal.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/DBMI-SQLite-drive-error-when-running-i-segment-stats-with-vector-map-creation-tp5291318p5291397.html
