[GRASS-user] DBMI-SQLite drive error when running i.segment.stats (with vector map creation)
Moritz Lennert mlennert at club.worldonline.be
Wed Oct 19 08:09:19 PDT 2016
On 19/10/16 10:42, Blumentrath, Stefan wrote:
> The “.” could be allowed if quoted identifiers were used, but that would
> be a quite invasive change and can have side effects on many other modules.
> Furthermore quoted identifiers can be handled differently in the
> different DB backends, thus code complexity will increase.
> In general it is also risky if the software alters your data (like
> renaming columns or even maps) at least if that behavior is not clearly
> documented...
Even though I agree with this in principle, in the case at hand here
(i.segment.stats) the issue is vector attribute column names based on
raster names. I don't think that there is much risk there.
> Handling this in the code is at least not trivial as it either would
> require significant changes.
Again, for many cases this is very true. Here, I believe that a simple:
colname = colname.replace('.', '_')
is enough.
Implemented in r69707.
James, just reinstall once again and it should work.
Moritz
