[GRASS-user] i.segment.stats memory usage error
James Duffy
james.philip.duffy at gmail.com
Thu Oct 27 06:38:07 PDT 2016
On 27 October 2016 at 13:53, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 27/10/16 12:51, James Duffy wrote:
>> On 27 October 2016 at 11:45, Moritz Lennert
>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>> wrote:
>> Le 27 octobre 2016 12:35:14 GMT+02:00, James Duffy
>> <james.philip.duffy at gmail.com <mailto:james.philip.duffy at gmail.com>>
>> a écrit :
>> >On 27 October 2016 at 11:08, Moritz Lennert
>> >wrote:
>> >> Le 27 octobre 2016 11:22:02 GMT+02:00, James Duffy <
>> <mailto:james.philip.duffy at gmail.com>> a écrit :
>> >> >Hello,
>> >> >I'm trying to use i.segment.stats with GRASS 7.0.4 in the
>> osgeolive
>> >> >32bit
>> >> >operating system.
>> >> >Prior to using this tool I have successfully created my segmented
>> >map
>> >> >using
>> >> >i.segment.
>> >> >When I try to execute the following command:
>> >> >i.segment.stats --overwrite --verbose map=gp_seg_optimum at gp1 \
>> >> >rasters=gp_ortho.1 at gp1,gp_ortho.2 at gp1,gp_ortho.3 at gp1,gp_ort
>> ho.4 at gp1
>> >> >raster_statistics=min,max,mean,stddev,variance,sum \
>> >> >csvfile=/home/jpd205/Wales_GRASS/GarronPill/gp_seg_stats \
>> >> >separator=comma
>> >> >I get this error:
>> >> >Calculating geometry statistics
>> >> >ERROR: G_malloc: unable to allocate 4273800320 bytes of memory at
>> >> > /tmp/tmpgzUtnA/r.object.geometry/main.c:129
>> >> This is coming from r.object.geometry.
>> >> What are your region settings (g.region -p) ? How many segments do
>> >you
>> >> have ?
>> >GRASS 7.0.4 (GarronPill):~ > g.region -p
>> >projection: 99 (OSGB 1936 / British National Grid)
>> >zone: 0
>> >datum: osgb36
>> >ellipsoid: airy
>> >north: 208007.00931776
>> >south: 207952.59780698
>> >west: 200993.90853302
>> >east: 201097.28911076
>> >nsres: 0.00430914
>> >ewres: 0.00430914
>> >rows: 12627
>> >cols: 23991
>> >cells: 302934357
>> Are you sure 4mm is correct for the resolution ?
>> Yes. It's high resolution imagery from a drone.
>> What does r.info <http://r.info> on
>> >> Try running I.segment.stats without requesting form statistics.
>> >Running:
>> >separator=comma
>> Default is to do form statistics, so the above line also does. I
>> have to admit that I don't know what happens when you give an empty
>> parameter such as
>> area_measures= or area_measures=""
>> What does r.info <http://r.info> gp_seg_optimum give you ?
>> | Map: gp_seg_optimum Date: Thu Oct 27 06:45:57
>> 2016 |
>> | Mapset: gp1 Login of Creator:
>> jpd205 |
>> | Location:
>> GarronPill |
>> | DataBase:
>> /home/jpd205/Wales_GRASS |
>> | Title: ( gp_seg_optimum
>> | Timestamp:
>> none |
>> | Type of Map: raster Number of Categories:
>> 0 |
>> | Data Type:
>> CELL |
>> | Rows:
>> 12627 |
>> | Columns:
>> 23991 |
>> | Total Cells:
>> 302934357 |
>> | Projection: OSGB 1936 / British National
>> Grid |
>> | N: 208007.00931776 S: 207952.59780698 Res:
>> 0.00430914 |
>> | E: 201097.28911076 W: 200993.90853302 Res:
>> 0.00430914 |
>> | Range of data: min = 35 max =
>> 133556294 |
> Ok, I think I see at least part of the problem: in GRASS 7.0 i.segment
> numbers segments non sequentially, i.e. whenever a new segment is created
> out of the merger of two existing segments, a new id is assigned. In GRASS
> trunk (the development version) i.segment is rewritten to, at the end,
> number all segments sequentially from 1 to the number of segments.
> r.object.geometry allocates memory according to the new system. As it says
> in the code:
> /* REMARK: The following is only true if object ids are continuously
> numbered */
> n_objects = max - min + 1;
> obj_geos = G_malloc(n_objects * sizeof(struct obj_geo));
> So, one solution would be to use the development version of GRASS.
> Another would be to run r.clump on the result of the segmentation in order
> to renumber the segments before running it through i.segment.stats.
This option seemed the most straightforward given my current setup. I ran
r.clump with diagnoal enabled, and the output looked good. It only took
2mins to run.
I then proceeded with the original i.segment.stats command and got the
following:
Calculating statistics for raster gp_ortho.1 at gp1
ERROR: G_realloc: unable to allocate 572000 bytes of memory at
raster/r.univar/r.univar_main.c:324
It looks like the tool got further, but is still getting stuck on
something...
> A third option, potentially a bit faster than the second, would be to
> write a little script which gets all category values from the segment map
> (using r.category), and reassigns sequential category values to those using
> r.reclass. I.e. something like this:
> r.category segment_map | awk 'BEGIN{cat=1} {printf"%d=%d\n", $1, cat;
> cat++}' | r.reclass segment_map out=sequential_segment_map rules=-
> Moritz
James
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161027/b425901f/attachment-0001.html>
