[GRASS-user] i.segment.stats memory usage error
Moritz Lennert
mlennert at club.worldonline.be
Thu Oct 27 07:15:59 PDT 2016
On 27/10/16 15:38, James Duffy wrote:
> On 27 October 2016 at 13:53, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> On 27/10/16 12:51, James Duffy wrote:
> On 27 October 2016 at 11:45, Moritz Lennert
> <mailto:mlennert at club.worldonline.be>>> wrote:
> Le 27 octobre 2016 12:35:14 GMT+02:00, James Duffy
> <james.philip.duffy at gmail.com
> <mailto:james.philip.duffy at gmail.com>
> <mailto:james.philip.duffy at gmail.com>>>
> a écrit :
> >On 27 October 2016 at 11:08, Moritz Lennert
> >wrote:
> >> Le 27 octobre 2016 11:22:02 GMT+02:00, James Duffy <
> <mailto:james.philip.duffy at gmail.com>>> a écrit :
> >> >Hello,
> >> >I'm trying to use i.segment.stats with GRASS 7.0.4 in
> the osgeolive
> >> >32bit
> >> >operating system.
> >> >Prior to using this tool I have successfully created my
> segmented
> >map
> >> >using
> >> >i.segment.
> >> >When I try to execute the following command:
> >> >i.segment.stats --overwrite --verbose
> map=gp_seg_optimum at gp1 \
> >rasters=gp_ortho.1 at gp1,gp_ortho.2 at gp1,gp_ortho.3 at gp1,gp_ortho.4 at gp1
> >> >raster_statistics=min,max,mean,stddev,variance,sum \
> >> >csvfile=/home/jpd205/Wales_GRASS/GarronPill/gp_seg_stats \
> >> >separator=comma
> >> >I get this error:
> >> >Calculating geometry statistics
> >> >ERROR: G_malloc: unable to allocate 4273800320 bytes of
> memory at
> >> > /tmp/tmpgzUtnA/r.object.geometry/main.c:129
> >> This is coming from r.object.geometry.
> >> What are your region settings (g.region -p) ? How many
> segments do
> >you
> >> have ?
> >GRASS 7.0.4 (GarronPill):~ > g.region -p
> >projection: 99 (OSGB 1936 / British National Grid)
> >zone: 0
> >datum: osgb36
> >ellipsoid: airy
> >north: 208007.00931776
> >south: 207952.59780698
> >west: 200993.90853302
> >east: 201097.28911076
> >nsres: 0.00430914
> >ewres: 0.00430914
> >rows: 12627
> >cols: 23991
> >cells: 302934357
> Are you sure 4mm is correct for the resolution ?
> Yes. It's high resolution imagery from a drone.
> What does r.info <http://r.info> <http://r.info> on
> >> Try running I.segment.stats without requesting form
> statistics.
> >Running:
> >i.segment.stats --overwrite --verbose map=gp_seg_optimum at gp1 \
> >separator=comma
> Default is to do form statistics, so the above line also does. I
> have to admit that I don't know what happens when you give
> an empty
> parameter such as
> area_measures= or area_measures=""
> gp_seg_optimum give you ?
> | Map: gp_seg_optimum Date: Thu Oct 27
> 06:45:57
> 2016 |
> | Mapset: gp1 Login of Creator:
> jpd205 |
> | Location:
> GarronPill |
> | DataBase:
> /home/jpd205/Wales_GRASS |
> | Title: ( gp_seg_optimum
> | Timestamp:
> none |
> | Type of Map: raster Number of Categories:
> 0 |
> | Data Type:
> CELL |
> | Rows:
> 12627 |
> | Columns:
> 23991 |
> | Total Cells:
> 302934357 |
> | Projection: OSGB 1936 / British National
> Grid |
> | N: 208007.00931776 S: 207952.59780698 Res:
> 0.00430914 |
> | E: 201097.28911076 W: 200993.90853302 Res:
> 0.00430914 |
> | Range of data: min = 35 max =
> 133556294 |
> Ok, I think I see at least part of the problem: in GRASS 7.0
> i.segment numbers segments non sequentially, i.e. whenever a new
> segment is created out of the merger of two existing segments, a new
> id is assigned. In GRASS trunk (the development version) i.segment
> is rewritten to, at the end, number all segments sequentially from 1
> to the number of segments.
> r.object.geometry allocates memory according to the new system. As
> it says in the code:
> /* REMARK: The following is only true if object ids are
> continuously numbered */
> n_objects = max - min + 1;
> obj_geos = G_malloc(n_objects * sizeof(struct obj_geo));
> So, one solution would be to use the development version of GRASS.
> Another would be to run r.clump on the result of the segmentation in
> order to renumber the segments before running it through
> i.segment.stats.
> This option seemed the most straightforward given my current setup. I
> ran r.clump with diagnoal enabled, and the output looked good. It only
> took 2mins to run.
> I then proceeded with the original i.segment.stats command and got the
> following:
> Calculating statistics for raster gp_ortho.1 at gp1
> ERROR: G_realloc: unable to allocate 572000 bytes of memory at
> raster/r.univar/r.univar_main.c:324
> It looks like the tool got further, but is still getting stuck on
> something...
Yes, now there a memory issue in the part where it uses r.univar to
calculate statistics per segment on one of the spectral bands.
What does r.info on the clumped map give you ?
Moritz
