On Fri, 28 Oct 2016, Vaclav Petras wrote: > I haven't seen the behavior before, so perhaps you just had some map > unchecked in Layers tab. Of course some checking and unchecking might be > cause of a problem. I had added and removed layers so that might explain it. Let's consider the issue closed for now. Thanks, Rich
