[GRASS-user] Vector legends: 2 out of 3 with duplicates
Vaclav Petras wenzeslaus at gmail.com
Fri Oct 28 14:02:24 PDT 2016
On Fri, Oct 28, 2016 at 4:18 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
>   So, after quitting and re-starting GRASS it displays correctly. How do we
> figure out what happened?
>   I can make some new maps and see what happens if that helps.
I haven't seen the behavior before, so perhaps you just had some map
unchecked in Layers tab. Of course some checking and unchecking might be
cause of a problem.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161028/9fe5b151/attachment.html>
