[GRASS-user] Grass 7 and postgresql
Markus Neteler neteler at osgeo.org
Fri Sep 2 11:52:15 PDT 2016
On Sep 2, 2016 6:45 PM, "Nikos Alexandris" <nik at nikosalexandris.net> wrote:
> GRASS 7.3.svn (wgs84):~ > db.tables -p
> DBMI-PostgreSQL driver error:
> Connection failed.
> could not connect to server: No such file or directory
>    Is the server running locally and accepting
>    connections on Unix domain socket "/run/postgresql/.s.PGSQL.5432"?
Can you connect with the psql command?
Is the service reachable at port 5432?
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/f990be20/attachment.html>
