[GRASS-user] Grass 7 and postgresql
Nikos Alexandris nik at nikosalexandris.net
Fri Sep 2 13:53:01 PDT 2016
Nikos Alexandris:
>> GRASS 7.3.svn (wgs84):~ > db.tables -p
>> DBMI-PostgreSQL driver error:
>> Connection failed.
>> could not connect to server: No such file or directory
>>    Is the server running locally and accepting
>>    connections on Unix domain socket "/run/postgresql/.s.PGSQL.5432"?
Markus Neteler:
>Can you connect with the psql command?
>Is the service reachable at port 5432?
Yes
Nikos
