[GRASS-user] Grass 7 and postgresql
Benoit ANDRE benoit.andre at bcgeol.be
Sat Sep 3 09:43:37 PDT 2016
When I tried grass 7.0.0 when it  has been released, in 2015, I remember it
was working. But it was only a test and I continued To work whit 6.4.4.
Le 2 septembre 2016 20:52:28 Markus Neteler <neteler at osgeo.org> a écrit :
> On Sep 2, 2016 6:45 PM, "Nikos Alexandris" <nik at nikosalexandris.net> wrote:
>> GRASS 7.3.svn (wgs84):~ > db.tables -p
>> DBMI-PostgreSQL driver error:
>> Connection failed.
>> could not connect to server: No such file or directory
>>    Is the server running locally and accepting
>>    connections on Unix domain socket "/run/postgresql/.s.PGSQL.5432"?
> Can you connect with the psql command?
> Is the service reachable at port 5432?
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160903/710d9593/attachment.html>
