[GRASS-user] Specifying wxPython version at grass start [UPDATE]
Rich Shepard
rshepard at appl-ecosys.com
Sat Sep 3 10:43:38 PDT 2016
On Sat, 3 Sep 2016, Anna Petrášová wrote:
> The error comes from gui/wxpythoncore/globalvar. I don't think there
> were any significant changes. If you are able to edit and recompile,
> try to find out where the error (invalid literal for int) comes from,
> I suggest to start here:
> https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/globalvar.py#L78
I added a couple of print statements; 7.2 is compiling now.
> Also check if you have GRASS_WXVERSION defined, you don't need to
> define when you run the default version.
No GRASS_WXVERSION defined.
Rich
