[GRASS-user] create location from CLI
Sajid Pareeth spareeth at gmail.com
Tue Sep 6 07:13:07 PDT 2016
Hi
>    I'm trying to understand the simplest way in GRASS7 to create a
> location from the command line without using a georeferenced file.  So far,
> it appears to be
> % grass70 -c newLocation
Did you try parsing the EPSG code of the location you want to create?
For example:
grass71 -c epsg:3035 /home/user/grassdata/mynewlocation
The above command will create a new location in epsg 3035 projection.
You can find some details here:
https://grasswiki.osgeo.org/wiki/GRASS_Location_Wizard#GRASS_GIS_7:_Creating_locations_from_command_line
Best
Sajid
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160906/fc39958c/attachment.html>
