[GRASS-user] grass73: python module name issue
Rich Shepard
rshepard at appl-ecosys.com
Wed Sep 7 08:52:16 PDT 2016
On Wed, 7 Sep 2016, Vaclav Petras wrote:
> I suppose this means no output. No traceback means that it works. So numpy
> works in the GRASS GIS session and it works outside.
Vaclav,
Correct.
> OK, still no clues for me. Can you run the GUI (what you get when you start
> or/and g.gui from command line - there should be no difference but you can
> check), switch to Python tab and execute:
> import sys
> print (sys.path)
> print (sys.version)
> import numpy
Cannot copy from the tab window to here. See attached .png.
> Also, you can check which Python version is used in the command line:
> python --version
$ python --version
Python 2.7.5
> Finally, you can try to find where numpy actually is and compare it with
> what sys.path is saying.
/usr/lib/python2.7/site-packages/numpy
It seems that sys.path is not picking up this package. Interesting.
HTH,
Rich
Type: image/png
Desc:
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160907/81fe6f2d/attachment-0001.png>
