[GRASS-user] i.landsat.rgb disappeared in Grass7
    Markus Neteler
    neteler at osgeo.org
    Thu Sep  8 13:13:36 PDT 2016
On Sep 8, 2016 9:04 PM, "anna zanchetta" <ciupava at gmail.com> wrote:
> Hi all,
> I was launching i.landsat.rgb from Grass 7.0.4 and got the message in
terminal "command not found". Indeed the 64 manual page [*] refers to it
and redirects to a non-existing analogous page in the 70 manual.
This is just an automatically generated box...
> After some look-around I've finally realized that the module is now
called i.colors.enhance, as by Markus' post here [^].
> As a simple user, I'd suggest that the page from the manual 64 should
point to the enhance in 70, and here specified that the former name was
different.
A complex rewrite script would be needed then. Better to blacklist the old
documentation :)
> Let me know please if maybe there's a list of changes between different
Grass versions, so that I could avoid this "much ado about nothing".
Sure, here it is
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
There are included the lists of renamed, removed etc module in that page.
Markus
> Anna
> * https://grass.osgeo.org/grass64/manuals/i.landsat.rgb.html
http://courses.neteler.org/processing-landsat-8-data-in-grass-gis-7-rgb-composites-and-pan-sharpening/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160908/66b0b25f/attachment-0001.html>
